engine temp
engine temp
I want to get a gauge to more accurately check the engine temp,
After browsing around I see you can buy a temp thing to measure either water, oil or head temperatures.
Whats the best to monitor (head or water I assume) also, which spot on the particular item would be good to mount the sensor (where along the water cycle, or where on the head would it be best)
I only want to get one, which would be the best to check the engine temp?
