white foam
Old 04-06-2005, 04:37 PM
Taphee6's Avatar
Default white foam
Anyone ever have a white foam form on the oil fill cap and tube? It almost looks like lith grease? What is it and what causes it?
Old 04-06-2005, 04:47 PM
sandking's Avatar
Sounds like moisture in the oil.
Old 04-06-2005, 04:50 PM
Viper's Avatar
Condensation in the oil.
Caused by not heating up the car all the way ( like a 15-20 minute ride to work ).
Very normal - I spent $$$ checking into it thinking something was wrong 2 years ago..
Old 04-06-2005, 04:52 PM
Taphee6's Avatar
Default oil
I just changed the oil when i found this. The oil from the pan and filter look good.
Old 04-06-2005, 04:54 PM
30th droptop's Avatar
Hopefully it's just condensation, as has been said. Pull the dipstick and make sure your oil doesn't look like a milkshake. If so, you'll need to find the source of the coolant-to-oil leak right away (head gasket, cracked head, etc.).
Old 04-06-2005, 07:09 PM
Dustin Butts's Avatar
Do you run a full PCV system? Running around on the street without a pcv system(especially in cold weather) can cause this. It happened to me....put the pcv back on and no more sprack in the oil cap.
Old 04-06-2005, 07:11 PM
Taphee6's Avatar
Default yep````````````````````````
I have a pvc and catch can....
Old 04-06-2005, 07:16 PM
Are you losing any water from your coolant tank? Have you checked?
