Sealing Rocker bolt holes
Old 04-09-2005, 04:23 AM
Lvmyz28's Avatar
Default Sealing Rocker bolt holes
I ported the heads on my LS1 and can't seem to get the rocker bolt holes in the intake ports to stop leaking. I first used red RTV sylicone and that stuff is garbage for sealing up threds, then I tried Permatex's high temp teflon thred sealer, and I still seem to be leaking some oil. Has anyone every tried to use engine epoxy or something of that sort to seal off the rocker bolt hole in the intake port?
Old 04-09-2005, 05:13 AM
Diamond Jim's Avatar
Go to the local Chevy dealer parts counter, and tell them you want the "GM Thread Sealer" that is used on the intake manifold bolts on vortec engines. It is a combination thread locker and thread sealer. It probably has a million other uses but when I changed the intake manifold last time, I went by the book and went and got some of it from the dealer. Be warned they are proud of it!
Old 04-09-2005, 05:25 AM
ssheets's Avatar
How proud?
Old 04-09-2005, 09:44 AM
LS1TECH Sponsor
Steve Burger's Avatar
Use Blue Loctite it works great.
Old 04-09-2005, 05:20 PM
oange ss's Avatar
actually I believe green Locktite is the sealer/lock combo
Old 04-09-2005, 06:44 PM
redline2k's Avatar
You could use arp thread sealer.
Old 04-09-2005, 11:08 PM
felton316's Avatar
I've always had great luck with the ARP thread sealer.
Old 04-09-2005, 11:24 PM
11 Second Truck Club
L-EATER's Avatar
I use Rector-Seal pipe thread sealant which is used for natural gas and water piping in the plumbing trade. It will seal things that other sealants won't and I have been using it in engines for about 10 years now with no problems.
Quick Reply: Sealing Rocker bolt holes
