how much can a stock rod and crank hold?
Old 04-10-2005, 09:24 PM
eric01ss's Avatar
Default how much can a stock rod and crank hold?
How much power can the stock rod and crank hold in a ls1?
Old 04-11-2005, 11:58 AM
M_T_0's Avatar
99 and newer 550rwhp is about it, on the 97/98 replace the rod bolts and you should be good to 550rwhp. the stock crank will hold a little more than the stock rods but past 600rwhp a good set of forged internals is really cheap compared to the downside. I think that most people are having good luck with eagle (now but not the early stuff) and it is around $1500 for rods and crank (you can get a stroker for the same price also).
Good luck
More Than Zero
