What size ratio rockers?
Old 04-12-2005, 11:56 AM
blownhtm's Avatar
Default What size ratio rockers?
I have a 388 CI.(all bore)11:7 LS1. It has a Cam motion 230/236 .595/.598 114 Lsa cam, Comp R lifters, Chet Herbert pushrods, and Rev 1116 dual springs. It currently has stock rocker arms that are going bad. Can I use 1.8 rockers to gain performance? This is not in a dailly driver car, its in an off-road car. What is the best rockers I can buy for around $500? thanks, Ted.
Old 04-12-2005, 12:00 PM
jrp
SN95 Director
jrp's Avatar
buy the nasty nate retro fitted stock replacements.
Old 04-12-2005, 12:48 PM
PREDATOR-Z's Avatar
Crane variable lift rockers.
That way you'll benefit from higher lifts at .200, .250, .300 and it goes back to 1.72 at .600.
Check VINCI website
http://www.vincihighperformance.com/
Old 04-12-2005, 08:13 PM
blownhtm's Avatar
Check VINCI website
If you use these accelerated lift rockers, do you have to use the accelerated lift cam? Crane and VHP make it sound that way.
Old 04-12-2005, 10:09 PM
QuietTahoe's Avatar
No, but I'm sure they wouldn't mind if you bought one!!!!
Old 04-13-2005, 04:19 PM
mrr23's Avatar
no you do not. on their AFR test vette, they used the 1.7 accelerated lift rockers with the comp cam 220/224 with .581/.581 lift.
