Craftsman Valve Spring Compressor
Old 04-12-2005, 08:31 PM
SSPerformance's Avatar
Default Craftsman Valve Spring Compressor
Will this work with the LS1 head. for the one time im gona chnage springs in my heads i dotn feel like spending 120 on one from thunder racing
tool
Old 04-12-2005, 08:33 PM
jrp
SN95 Director
jrp's Avatar
spend the money on a good tool, trust me. you'll use it more then you think and you can always rent/loan it out to peeps in the area as well. a good valvespring tool is worth its weight in gold. i'd opt for the crane/vhp.
Old 04-12-2005, 09:01 PM
bigdsz's Avatar
That thing only works with the heads off, it also looks like some kind of torture chamber apparatus. Advance Discount Auto parts has a spring compressor for less than $20 that does a great job.
Old 04-12-2005, 09:30 PM
That's what she said...
TheBlurLS1's Avatar
my uncle built a tool for me at work to change valvesprings with. he turned it out on a lathe from a piece of 1.5" steel. one end is about 3/8" and chucks up into a drill press. the other end is a little smaller than a retainer, then bored out, then a window is cut in the side.
you put the head on the drill press, then chuck up the 3/8" side, the use the drillpress handle to compress the spring and change the lock thru the little carved out window. worked like a CHAMP! blaSSt let me run over and use his drill press . we layed the head up on the press and got it at the right angle with a few blocks of wood. put a red rag in the combustion chamber to hold the valves open and viola. here's a picture of it......
Attached Thumbnails Craftsman Valve Spring Compressor-valvespringcompressor.jpg
Old 04-12-2005, 09:42 PM
01_SuperSlow's Avatar
The Crane tool makes the job sooooooooo much easier.
Old 04-13-2005, 06:06 AM
Z06 Steve's Avatar
I make a valvespring tool $29 shipped.My Sears tool is in the trash!I'm in the tools section for details.
Old 04-13-2005, 09:18 AM
Joe Vinci's Avatar
We have the VHP/Crane spring tool on special for $105.99. Here is a link to the page.
http://www.vincihighperformance.com/superwebdeals.HTML
If you have any questions about the tool, give me a call. It is by far the best valve spring tool we have ever used.
Old 04-13-2005, 09:27 AM
MrDude_1's Avatar
tool
it was jsut said, but i'll say it again anyway.
for that one to work, you need to take the head off.... one half of that tool holds the valve, the other half compresses the spring. works ok on a bench.
Quick Reply: Craftsman Valve Spring Compressor
