Broke a pushrod in an A4 with only boltons!
Old 04-14-2005, 11:31 AM
Bad Blu Formula's Avatar
Default Broke a pushrod in an A4 with only boltons!
For some reason, my car only has full exhaust, a converter, pully, and a lid. My rev limiter is set at 6300 and I have not ever hit that. My car shifts at 6100 too. Anyways, the other day I wasn't even driving my car hard or anything, I only took it up through second gear without downshifting and all of a sudden I have my SES light blinking as a result of a misfire after I came to a stop. My car continued to misfire after that. We went through alot of things before we finally pulled the valve cover off and noticed that my intake pushrod on the #6 cylinder had decided to disappear down into my head. So right now my head is off and the pushrod breaking beast will be back together tomorrow.
Old 04-14-2005, 11:35 AM
~JOSHUA's Avatar
That's poopy. Good luck! I wonder why it would break like that? Must have been a casting flaw.
Old 04-14-2005, 11:41 AM
dalejr8ls1's Avatar
thats some wierd stuff, did u swap out the pushrods when doing heads, if so check length...other than that my friend had a pr bent while shipping so double check that stuff. Good Luck.
