i need some technical opinions on cams
i need some technical opinions on cams (J-ROD help)
i want a bigger cam. i am bored with my TR224 114. it is a great cam, but i only got it because of smog in california. these are the ones i am looking at.
will any of these require anything special to run right. also installing. does it require putting in at any point besides dot to dot?
TR 230-236-112 590/598
LG G5X3-112 2??-2?? 600/610
Futral F14-112 232-234 598-598
i want something immpressive, but not crazy. i have all mods in my sig so i am setup for most cams. i have stock length hardened pushrods also. not sure if that will play a factor.
maybe LG G5X4 not sure how wild it is though on lift.
or trex
please help.
or trex
please help.
The G5x3 will put a big smile on your face , if you r running 112lsa and clynderheads ,probably u would need some piston notching , and heads miling .
A good tune will improve this cam ability .....
you can hit the 450hp like penuts ,,, no worries man ,,, good luck ....
is it the lift that causes the clearance issues? because the thunder cam is under .600 for lift. they seem to be a big difference. 590/598 vs. 600/610. what is the power difference? i want the 112 lsa on either cam.
they said it was due to lift and oversize valves. they due rent a flycutter for 100 + 350 deposit. that kinda kills my whole upgrading cam swap. i really dont want to fork out $900 to get this done. that sucks.
