oil pump , timing chain
Old 04-16-2005, 10:18 PM
CATDIESEL's Avatar
Default oil pump , timing chain
I am installing a rollmaster double row timing chain, and an slp ported oil pump . I remember reading that the pump is machined so you dont need the spacer plates that come with the chain. I bolted the pump on and it seems to clear the chain. Just would like to know if anyone can confirm that this will be ok without the spacers
Old 04-17-2005, 02:44 PM
santino04's Avatar
Im positive that on the SLP site it says "if using SLP oil pump no need to use spacers" Im also pretty sure that there double roller timing chain is a Rollmaster piece with a jacked up price. Good Luck
