Burning smell
Old 04-20-2005, 01:03 PM
rgaynor85's Avatar
Question Burning smell
Im looking at a 2001 trans am with 37k miles on it. the other day i test drove it and the guy let me stomp on it. it has a 6speed witch im used to driveing but when i got to the next red light i got a wiff of some buring i dunno if thats normal for an ls1 after revving it up or would that be the clutch if i wasnt driving right.or does it just sound like a bad car. also 3rd gear and higher were hard to find had to wiggle shifter around to get it in
plz help
Old 04-20-2005, 01:07 PM
777's Avatar
that is called the clutch going out...i don't really see any other explanation for it...with stock shifter 3rd and up gears are hard to find...
Old 04-20-2005, 01:09 PM
rgaynor85's Avatar
so they are always hard to find 3rd and up, but the car did feel good as far as the clutch
Old 04-20-2005, 01:10 PM
rgaynor85's Avatar
also does it get easier with good short shifter
Old 04-20-2005, 01:14 PM
iamsickofitall's Avatar
3rd gear is a bitch with the stock shifter...much nicer with a short stick...my guess would also be clutch stink...can you describe the burning smell a little better?
Old 04-20-2005, 01:17 PM
rgaynor85's Avatar
umm well when i stoped at the rd light the tees were off and i just got a quick smell or burning didnt smell like oil, and its wasnt rich mixture i had almost like the smell of a brand new engine when you beat on it before its broken in
Old 04-20-2005, 01:19 PM
777's Avatar
that definitely sounds like clutch to me...and yes a pro 5.0 shifter would help it BIG time...i can't miss 3rd even if i try...(obviously i can but it is really hard to miss it )
Old 04-20-2005, 01:21 PM
rgaynor85's Avatar
so does that sound like a bad clutch or is it common when your new to a stick to burn it a little and smell like that
Old 04-20-2005, 01:24 PM
rgaynor85's Avatar
oh and someone told me it sounds like syncros with the shifting is it really normally that hard to get 3rd to the point that you have to wiggle it and play to find it
Old 04-20-2005, 01:25 PM
777's Avatar
well depending on how well you drive...it is very easy to burn the clutch like that if you aren't used to driving stick...but if you were just in gear coasting and then floored it and let off...put in nuetral and stopped and you smelled it...that is a bad clutch
Old 04-20-2005, 01:27 PM
rgaynor85's Avatar
no i was already driveing the car a little and im not good takeing off i stalled it like 2 times and i took off from a stop then hit 2nd relatively hard, easy into 3rd then costedand stopped
Old 04-20-2005, 01:32 PM
777's Avatar
that's prolly your driving...how many miles on the car and what year is it...i wouldn't worry about it...sounds to me like you just aren't used to the m6...
Old 04-20-2005, 01:39 PM
rgaynor85's Avatar
2001 with 37k miles and what is an m6
Old 04-20-2005, 01:40 PM
rgaynor85's Avatar
oh manual 6
Old 04-20-2005, 02:49 PM
777's Avatar
yup clutch shouldn't be bad with only 37k miles if it is relativly a stock car (no cam, heads, or forced induction) it was most likely your driving (no offense) sounds like a good car if price is right...you'll love the ls1 for sure
Old 04-20-2005, 03:09 PM
rgaynor85's Avatar
none taken i never owned a stick so this is new to me only driven a couple hondas and hyundais in stick. the car is 18.5k tryng to get in cheaper and yes completely stock. i got a 88 monte ss with a 350 a little worked but still not enough
