turque spech on ls1 fly wheel any one???
Old 04-22-2005, 05:49 PM
LS1rscamaro's Avatar
Default turque spech on ls1 fly wheel any one???
does any one no the turque spec s on a ls1 manual fly wheel if that makes a difference
Old 04-22-2005, 05:58 PM
That's what she said...
TheBlurLS1's Avatar
Originally Posted by installuniversity
Install new flywheel and torque the 6 bolts progressively to 74 ft-lbs in a criss-cross pattern.
http://www.installuniversity.com/
go to lsx vehicals, then go to install documents, then mcleod clutch install. has all the tq specs on there
Old 04-22-2005, 06:10 PM
Tech's Avatar
Specifications - Torque Specification
Notes First Pass 15 lb. ft.
Second Pass 37 lb. ft.
Final Pass 74 lb. ft.
Copyright © 2005 ALLDATA LLC
Terms of Use
Old 04-22-2005, 07:00 PM
Loudmouth LS1's Avatar
From what i've been told, you should just impact it! I ****** torqued mine to spec, and triple checked it and had blue threadlock on 'em, and the ****** bolts backed out. I had to get another new tci flexplate cuz the bolt holes got all messed up, there went almost $200 down the drain!!!!
Old 04-23-2005, 10:46 AM
how about the presure plate to flywheel on a spec stage 3 cluch? should the presure plate be flush on the fly wheel or does it have a 1/16" gap?
Old 04-23-2005, 10:57 AM
LS1TECH Sponsor
Steve Burger's Avatar
Pressure plate will only go on one way. The touque spec is 52 Lb/ft. Use Loctite on the bolts and start the torque sequnce at 20, then 40, then 52.
