i need help with timing marks!!!
Old 04-23-2005, 12:36 PM
SlpLS1's Avatar
Default i need help with timing marks!!!
i know ur supposed to line the dots up.. but cant u be 180 degrees off.. or does it really matter.. plz i need help ASAP. call me if possible 602-791-4082 thxs jason!!
Old 04-23-2005, 12:47 PM
PREDATOR-Z's Avatar
http://www.ls1howto.com
Old 04-24-2005, 10:41 AM
vettenuts's Avatar
Don't spin the motor with 180 degrees off, and line up the dots correctly before you do. Use reference from above post.
Old 04-24-2005, 11:45 AM
PREDATOR-Z's Avatar
There is no way you could even turn the motor over if you were 180 off
