Z28 Governor?
Old 04-25-2005, 03:43 PM
cr0y's Avatar
Default Z28 Governor?
I have googled and i cant seem to find info on what speed the governor kicks in at on a 99 z28 M6. Can it be taken off, should it be taken off?
Old 04-25-2005, 04:01 PM
Cal
Cal's Avatar
It depends on the speed rating of the tires that came on the car. You can blow out the speed limiter with LS1edit or HPtuners. You want to make sure you have speed rated tires with 40 psi in them before you make any high-speed runs, though. Also, a tire that's had a flat repair no longer has a speed rating.
Old 04-25-2005, 08:38 PM
jrp
SN95 Director
jrp's Avatar
235's OEM = 118
245's+ OEM = 150+
i bought my car used but found out the day i got it , that it had the limiter . checked the RPO sticker and it indeed came with 235's OEM .
Old 04-25-2005, 08:52 PM
cyphur's Avatar
jerami thats got to suck. i've only go over 150 once...but i maxed the bitch out when i did. it was in my old formy ws6.
Old 04-25-2005, 10:02 PM
Bombguy99z28's Avatar
160 for z rated tires... I think I was somewhere around 5300 rpm in 5th when I hit it.
Old 04-25-2005, 10:06 PM
RIP April 14, 2008
Diolar Magnum's Avatar
Location: the land where cars repeatedly hit my bumper when I'm in the store...
as far as I know the top end stock limit is 161 mph.
Brad
Old 04-26-2005, 08:55 AM
12secSS's Avatar
For Z-rated tires, using HPTuners to look at the OEM programming, it is 162 MPH.
Old 04-26-2005, 12:09 PM
10 Second Club + 14 Second Truck Club
antz01ta's Avatar
mine cut off at 157.
Old 04-26-2005, 02:01 PM
BigSteele's Avatar
mines at 120, I think my door sticker says it came with 235s, didnt know about different govenors for different stock tires
Old 04-26-2005, 02:41 PM
luv2spd's Avatar
My stock program said 160. I've heard the 162 number though as well.
Quick Reply: Z28 Governor?
