Need Help with cam and exhaust
Old 04-26-2005, 01:27 AM
Zerokube's Avatar
Default Need Help with cam and exhaust
I'm planning on putting on headers, y pipe, and a whole system but was wondering will everything just bolt up? or wll i need welding done?
also with the cam, what happens after i put it in and start it up? does every light come on?
If anyone can guide me that would be cool. Plus i need what i need for all that.
Old 04-26-2005, 02:12 AM
TNormZ28's Avatar
You can get everything with the exhaust to just bolt up. I did Jet Hot longtubes, off road y pipe and an Hooker catback exhaust. I got some better band clamps but no welding. As for the cam there is only one cam that you can install and NOT need a tune immediately, and that is the 02+ LS6 cam. For a cam install under .600 lift you'll need:
cam
valve springs comp cams 918's
front cover gasket
water pump gaskets
coolant
tune
I'd go ahead and change the oil and filter too.
Good luck.
Old 04-27-2005, 06:45 PM
Bill Bowling's Avatar
Talking
For a cam install go to:
http://www.bowlingss.com/Mods/Instal...stallation.mht
Use 5/16 and 1/4" rods(18" long) to hold the lifters up.
Good luck. Just did mine a few weeks ago.
Bill
