oil pressure
Old 04-26-2005, 02:13 PM
BigSteele's Avatar
Default oil pressure
I have a 99, my oil pressure is usually around 50 according to the gauge.
Is this normal, I know most people recomend swapping the oil pump on the pre 01? cars dues to a weak pump, but mine seems like its doing the job good.
Whats the psi for a good pump? does the psi give indication of the pump condition or can an oil pump work good then suddenly "break" and loose pressure?
Old 04-26-2005, 02:16 PM
11 & 7 Second Clubs
Race Car Driver's Avatar
60 Lbs would be closer to average.
Old 04-26-2005, 05:38 PM
ta981's Avatar
My TA is at 40 psi @ Idle. Your PSI is pretty much normal. I wouldnt worry about it.
Old 04-27-2005, 10:14 AM
11 & 7 Second Clubs
And my bbc idles at 70 to 75 lbs.
Old 04-27-2005, 06:21 PM
Bill Bowling's Avatar
Talking
Mine runs about 50-60 idle and 70 at WOT. I do have a ported LS6 pump.
Bill
Old 04-28-2005, 09:54 AM
11 & 7 Second Clubs
I find it curious that there is such a wide range of oil pressures amongst the site users, anywhere from 20 to 60 lbs at idle. Wow, that shouldn't be.
Bill
Old 05-01-2005, 12:16 AM
soslo's Avatar
with my ported ls6 pump, and stock block, I see about 60 psi at idle, and 70+ at WOT. Somewhere just under 80 (maybe 78) is the highest I've seen
Old 05-01-2005, 04:14 PM
windshear's Avatar
My stock 02 T/A oil preasure at idle is 45PSI after warm-up. It starts as high as 60PSI when cold.
Old 05-01-2005, 06:48 PM
Camaro99SS's Avatar
My car idles at 45 when warm, runs about 60 cruising and 70 WOT. That's with the stock pump and German Syntec 0W30.
Jason
Old 05-01-2005, 09:01 PM
BigSteele's Avatar
so whats the problem with the 98-99(?) pumps?
what happens to make them lose pressure, is there a way to monitor/predict such an event?
