Heeeeeeeeeeeeeeelllllllllllllp Please
Old 04-27-2005, 12:24 AM
silvernblackcamaro's Avatar
Default Heeeeeeeeeeeeeeelllllllllllllp Please
After A Few Minutes Of Driving The Rpm's Skip And The Car Lags To Go Faster Please Help
Old 04-27-2005, 01:18 AM
WOT
WOT's Avatar
Need more info. Break it down as much as you can.
Old 04-27-2005, 01:23 AM
IT IS A98 Z28 SIX SPEED MM6 MN6 U PUSH THE GAS AND LETS SAY THE RPM IS AT 2.5 AND AFTER IT GOES TO 3.5 WHEN U ARE IN LETS SAY FIFTH GEAR ULL PUSH THE GAS AND IT REVS UP AND WONT EXCEED SPEED AND WHEN IT DOES IT GOES REAL SLOW
Old 04-27-2005, 01:50 AM
WOT
WOT's Avatar
From what you have said with the rpms going up and not the mph, i would say a roasted clutch
Old 04-27-2005, 02:08 AM
calongo_SS's Avatar
That's what I said in your other post. You've got clutch problems.
Old 04-27-2005, 02:35 AM
JZ'sTA's Avatar
Maybe a real bad 02 sensor, but it would then all of a sudden surge and drive normal.
Probally clutch.
Old 04-27-2005, 02:36 AM
PREDATOR-Z's Avatar
Clutch slipping
Old 04-27-2005, 02:42 AM
Originally Posted by PREDATOR-Z
Clutch slipping
what kind of clutch do u guys recomend the car is almost stock except for whats is below
Old 04-27-2005, 03:10 AM
PREDATOR-Z's Avatar
If you do not plan to mod further soon (ie: Head/cam, boost etc...), I would go with a 02>... Z06 clutch for excellent streetability (no chatter like with kevlar etc..)
Old 04-27-2005, 03:31 AM
CAN U GIVE ME MORE INFO PLEASE
Old 04-27-2005, 03:49 AM
PREDATOR-Z's Avatar
I meant Corvette Z06 OEM clutch and flywheel.
Or any stage 1 like SPEC + flywheel
A Stage 1 clutch is a great upgrade from stock for street use and will hold 400 horsepower. Stage 1 clutches include a metal backed / organic faced disk.
Old 04-27-2005, 04:24 AM
RedHatRdRacer's Avatar
yup sounds like the clutch, I have friends that run a SPEC stage 3 on a bone stock LS1 with 100shot... I run a Stage 4 from SPEC and i have no problems with it daily driven
Old 04-27-2005, 08:06 AM
sevanseriesta's Avatar
I am not sure what kind of a clutch I have a Know that it is a stage four but this thing is a beast I snapped a ford 9" center section and the the clutch never slipped.
Old 04-27-2005, 09:27 AM
PREDATOR-Z's Avatar
I wouldn't go higher than a spec 2 with his mods, I still would prefer a Z06 clutch assembly.
Spec 3 & 4 are for H/C cars and heavy rears.
Old 04-27-2005, 09:33 AM
HA heavy rears......... Sometimes those dont even hold up.....you know, go out, spend the extra money take 3 launces and snap center section shatered in half.
Ok done venting go the the z06 clutch save the rear.
Old 04-27-2005, 11:10 AM
prostock_bigblock's Avatar
It must be one of the 2 :-
fuel pump or clutch slipping .
Old 04-27-2005, 11:13 AM
Ew Ew Ew Me Me Me Ew Me
Is
Clutch Slipping
