Rings for stock bore?
Old 04-28-2005, 06:29 PM
JRcamaroZ28's Avatar
Default Rings for stock bore?
i'm in the process of doing a budget rebuild and was wondering if ther are any rings made for the stock bore other than GM repacements? I've searched around and havent seen anything so far. also atteched is a pic of my one bore what do you guys think of it? all of the other ones look the same. its a '98 w/ 39,000 on the clock. stock cross hatch is still there and some fine verticle lines on the top & bottom of the bores but no deep scratches.
JR
Old 04-28-2005, 09:25 PM
CharlieLed's Avatar
Sealed Power makes a ring set for stock bore....
Old 04-28-2005, 09:29 PM
tim99ws6's Avatar
I know mahle makes a piston for stock bore......and their pistons come with rings. Might wanna see if you can get ahold of Mahle and get a set of them?!
Old 04-29-2005, 09:37 AM
thanks, i'll give them a call later then and see what i can get.
JR
Old 04-29-2005, 12:03 PM
Dustin 98TA's Avatar
Im running the Sealed Power rings in mine with no oil consumption whatsoever after 20K+ hard miles.
