6.0 bore ?
Old 04-30-2005, 07:05 PM
coop5885's Avatar
Default 6.0 bore ?
how far can you bore out a 6.0liter, and what does that equal in cubic inches?
Old 04-30-2005, 07:12 PM
VSGLS1's Avatar
Search is your friend. The stroke will play a determining factor into CID.
Old 04-30-2005, 07:16 PM
coop5885's Avatar
i did search, but i ment ALL bore. couldnt find anything on that
Old 04-30-2005, 07:20 PM
Demon SS's Avatar
.030 over is no problem, on some 6.0L blocks you can do .060 over but you need to sonic check the block to make sure .060 is safe.
if you go .030 over with the stock stroke you get a 370ci setup
on a .060 bore and stock stroke it would be a 375ci setup
Old 05-01-2005, 12:45 AM
ArcticZ28's Avatar
Yep, got a 6.0 bored .060 over myself... Demon hit the nail on the head.
Old 05-01-2005, 11:29 AM
My2kz28's Avatar
Dont think it could be said any better. Great advice demon!
Old 05-01-2005, 12:43 PM
SSU'S Vice Mod
sb427f-car's Avatar
You on stock stroke then? How's that sucker rev with the extra bore?
Old 05-01-2005, 01:08 PM
ArcticZ28's Avatar
Yep, stock stroke. Can't tell you how it runs yet as I just swapped it in yesterday. I still have to put the heads and accessories on. I'm sure I'll be posting a vid once I do get it up and running though
Old 05-01-2005, 01:19 PM
BLWN1's Avatar
Whats going rate on a block or complete motor?
Old 05-01-2005, 01:48 PM
Demon SS's Avatar
as we are also in KY give us a call! you can reach brad today at 502-648-1192 to discuss this if you wish
Old 05-01-2005, 02:31 PM
SSU'S Vice Mod
sb427f-car's Avatar
Awsome...keep us posted.
Old 05-01-2005, 05:49 PM
landonew's Avatar
FYI, simple CI calculator
((Bore)\2)^2*(3.14)*stroke=displacement
derived from
Area of circle = pi(r)^2 where pi~3.14
volume of cylinder = Area_circle * length
bore = diameter = 2*r
Hope that helps future "ci" questions
Old 05-01-2005, 05:53 PM
Adrenaline_Z's Avatar
Is it true that boring an LSx block near the 0.060" over mark, would warrant
recentering the bores?
What is the major thrust side thickness after 0.060" over bore on a stock LSx
engine?
Old 05-01-2005, 06:44 PM
Demon SS's Avatar
we did a 6.0L ironblock 370ci setup with N2O heads and cam that made 463rwhp and 430rwtq N/A, so it should run very well
the iron blocks are great for FI or juice applications due to the extra strength.
Old 05-01-2005, 07:00 PM
JZ'sTA's Avatar
I agree.
Plus if you have it 30 over and something minor happens you can always bore it a little more.
Old 05-01-2005, 07:33 PM
SSU'S Vice Mod
sb427f-car's Avatar
Yeah, I know. And a much cheaper alternative to get some strength and some extra cubes.
Old 05-01-2005, 07:34 PM
SSU'S Vice Mod
sb427f-car's Avatar
Originally Posted by JZ'sTA
I agree.
Hum, that's a good idea...hadn't thought about that, but makes sense.
Old 05-01-2005, 07:36 PM
ArcticZ28's Avatar
Just FYI, a "safe" spray of nitrous would be a 200 shot on these things with a built bottom end
Old 05-01-2005, 08:07 PM
strokedls1's Avatar
Here is a copy oy my last blocks sonic test. I offset the bores to get maximum wall thickness. Thrust sides are all pretty thick, but the pin side on the inner pistons is where it can get thin.
Old 05-02-2005, 08:39 AM
Derek98z's Avatar
this is awesome. Exact stuff I am doing!
