in the process of installing my heads and cam
Old 05-01-2005, 07:17 PM
WS6FirebirdTA00's Avatar
Default in the process of installing my heads and cam
well i have everything off the car and started to put the cam in, well the cam in is the car now just gotta wait on oil pump and gaskets and i get to put it all back together. the passenger side head bolts were a bitch with the headers in there, the oil pump wasnt bad to get out at all. now we will see how the assembly goes.
ill get some sound clips when im done, F13, GMMG, ORY, AFR heads
Old 05-01-2005, 07:21 PM
conan's Avatar
I just got done with my motor swap last week. Always fun getting new toys.
Old 05-01-2005, 07:32 PM
DrkPhx's Avatar
It's much more fun to put it back on.
Old 05-01-2005, 09:50 PM
haha yeah i bet so, ill just take my time and it should be ok.
the best way i found out to take the pulley off the car was to take a 24mm inpact socket and put it in the hole of the pulley, put a 3/8 inch adaptor in the end of the socket and use that to put the puller on. worked out great for me. i read everyone else putting longer bolts but this was so simple, and free lol
Old 05-01-2005, 09:51 PM
any tips in putting it back together?
only thing i see being an issue is the oil pump, getting that tube back in there with the bolt. anything else that may be a problem? and wahts the best way to get the new pump in
Old 05-01-2005, 09:53 PM
soslo's Avatar
Are you putting a double roller timing chain on? That will only add to the aggrevation of getting the new oil pump in. It'll work, but it is frustrating - don't mess up the gasket...
Old 05-01-2005, 11:27 PM
no just an ls2
Old 05-02-2005, 12:41 AM
TNormZ28's Avatar
That will be a killer combo for power. I'm guessing 205's. Let us know 2 things. 1. how much power after tuned and 2. if you hear an annoying whistle.
Old 05-02-2005, 08:27 AM
will do, why do u ask about annoying whistle?? i have a slight whistle when its cold from the tb now but it goes away lol
Old 05-02-2005, 09:36 AM
bowtieman81's Avatar
Hey WS6, are you going to fire it up on the stock tune? If not, what is your car tuned for (headers, intake, etc.)? I am curious if I can put heads/cam in my car and get it to at least run on the tune for headers only.
Old 05-02-2005, 10:30 AM
LS1TECH Sponsor
Steve Burger's Avatar
It will run on a headers only tune. Not well but it will run. Tune ASAP.
Old 05-02-2005, 12:36 PM
what he said, im gonna retune some things before i fire her up, some of the basics for cam tuning
Old 05-02-2005, 01:58 PM
ArcticZ28's Avatar
The pickup tube will be a ***** in getting that little bolt started in the hole... amazing how they put the bolt on the utmost inopportune side of the flange.
Old 05-06-2005, 08:33 PM
well guys since my damn oil pump is on special order and will be next week before i get it i have been practicing with the old pump getting it on lol
right now the whole top end of the motor is about back together, went together very well. ill take some pics tomorrow.
Old 05-07-2005, 06:12 AM
98A4LS1's Avatar
I'm sitting here looking at the LS6 oil pump I ordered that I'm going to install when I do a cam swap. There are two bolt holes for the oil pickup tube. Does the pickup tube only have one hole drilled? If two, why not you use two bolts?
Old 05-07-2005, 09:01 AM
the tube only has one hole for a bolt. why dont u send me your pump so i can finish and ill send you mine when i get it haha jk
Old 05-07-2005, 09:08 AM
DrkPhx's Avatar
One is for the Corvette pick up tube. That hole and bolt faces frontward (when installed) compared to F-body bolt which is almost hidden when installed.
Old 05-07-2005, 08:30 PM
well this is how far i got now i am stopped right here, major pita waiting on special order parts
Attached Thumbnails in the process of installing my heads and cam-caminstall1.jpg
Old 05-12-2005, 09:17 AM
ok so anyone wanting to get an ls6 pump from gmpartsdirect, dont do it, they told me i was suppose to get the pump this week, now they told me it wont ship til next week. 2 damn weeks or more to get a damn oil pump, this is f$%@#^! rediculous. if i would have known this i would have never ordered from them
Old 05-12-2005, 09:22 AM
777's Avatar
shoulda went with tsp...anyhow your engine and bay are clean no a/c?
