buying order Q
buying order Q
just wanting some opinions on which to order first..should i go top end or bottom end first?...the block will be the last thing ordered..due to i dont feel like hearing about how it sits in the garage...
I would do the top end if it works with a setup you already have, that way you could run it with your bottom end while you are still gathering parts, etc. If you are building a comletely new setup... its whatever My advice if you are buying parts over a long period of time, make a plan, write it down and stick with it. Once you are committed people will persuade you to change components and specs and you will end up buying selling til you get pissed about a hobby...do what you want just my .02
Rob
Rob
