Milling AFR 225's
Milling AFR 225's
Inorder to hit my desired compression (11 to 1) I would have to mill the AFR 225's 72cc 50 thou. Does anyone know if that would effect the performance? Alright let me restate that a little. I know it will effect the performance the question is how and how much? Is it worth milling the 225's 72cc or wait for the 225 62cc's?
There is a thread on this.
https://ls1tech.com/forums/showthrea...hlight=AFR+225
I'm starting to feel like JRP
Location: Used to live in South Texas, Now in North Carolina
I don't think you can take the 72 ccs down that much. If i remember right you can only take 36 thousands off......which brings it to a 62cc chamber I think.
.036 off would put it closer to 66cc's
-Z.....We might have to knight you as his assistant
Taphee...give me a call at AFR if you want a little help with your combination.
Tony M.
(818)890-0616 Ext. 109
