Anyone have TREX and milled heads??
Old 05-03-2005, 12:21 PM
NickcZ28's Avatar
Default Anyone have TREX and milled heads??
Just like it says and if so did you flycut or have valve releifs??
Old 05-03-2005, 02:02 PM
Fireball's Avatar
yes (.040 milled) and yes...had to flycut ALOT
Old 05-03-2005, 05:24 PM
NickcZ28's Avatar
Would 2cc valve reliefs work, and how much power did you make??
Old 05-03-2005, 06:16 PM
Randy WS6's Avatar
I would like to know to, i have 2cc valve releafs 2.02 valves with .030 milled 5.3 heads
Old 05-03-2005, 10:04 PM
JF WS6's Avatar
If I remember correctly, I think Fireball had to notch 90 thou. out of the intake side and something like 75 thou. on the exhaust, his heads were milled .040 though.
I think with the heads milled that much, the P/V clearance was a negative 40 thou. into the flycut on the intake side.
I only remember because I'm attempting to do something similar, but I won't mill them down as much.
Old 05-04-2005, 07:41 AM
NickcZ28's Avatar
Waas it worth it?? I hust have stock valve size but portted heads??
Old 05-04-2005, 10:24 AM
Fireball's Avatar
I don't know how deep 2cc are but IIRC they are pretty substantial
I had .095 on the intake and .070 on the exhaust cut
Power curve is here:
http://home.comcast.net/~bkrzewinski/trexdyno.jpg
Note this was on 28" slicks not radials.
Old 05-04-2005, 11:04 AM
DanZ28's Avatar
2 cc = .122".
Old 05-04-2005, 12:25 PM
NickcZ28's Avatar
Thanx alot guys!!!!
