will solid engine mounts cause any problems?
Originally Posted by GuitsBoy
potential false knock. Banging exhaust has been known to trip the knock sensors.
I have a set of Spohn solid mounts to go in sometime in the next few days. So I can't tell you what they are like, but the people I've talked to say the vibes aren't so bad. LS1's are quite smooth running engines. There probably isn't alot of difference between solid and poly, except that the solid's are about 15 lbs lighter. With solid mounts, you eliminate those two big cast iron perches that the rubber mounts sit on.
