Stock Lifters with a G5X2
Old 05-03-2005, 03:26 PM
ZULater01's Avatar
Default Stock Lifters with a G5X2
Will this work? I tried to search and couldn't find anything. I need to know tonight that way I can order some from Comp if the stockers won't work. Thanks guys!
Old 05-03-2005, 03:50 PM
mike c.'s Avatar
i had stock lifters with my x2 cam and still with my x3 cam. no problems to report.
Old 05-03-2005, 03:53 PM
That's what she said...
TheBlurLS1's Avatar
well unless you want to pull the heads off and replace them, i would say stick with the stock lifters
tons of cars run big aftermarket cams, and hardly any of them pull their heads off for a cam swap, THEREFORE.........
unless you're like me and have pulled your heads to change the lifters and nothing else all in the name of the eternal quest for the ever illusive !tick mod
Old 05-03-2005, 04:00 PM
ZULater01's Avatar
lol.I have my heads off already for head swap, thats why I ask.
Old 05-03-2005, 04:05 PM
ZULater01's Avatar
Originally Posted by Unaffiliated Racing
Kenny..unless you go with some adjustable rockers to go with a set of R series lifters. Just keep the stockers..no sense in using a Comp OE replacement.
Cool, I will reuse the stockers.
TheBlurLS1's Avatar
shoulda included this information in the 1st post
how many miles are on the car? the stock lifters can handle that cam, and the stock replacements (comp 850's) are not a big improvement from the stockers. the comp r lifters, although better than the 850's, require an adjustable rocker arm to set the preload correctly.
if you have the money, i would look into the morel lifters. they are a VERY nice units (futral sells them i think?) as does racetechspeed. they are quite a bit for a set, but have alot of nice features.
example) they fill the lower part of the lifter bores better for improved oil pressure because of less oil loss thru the bottom (if your cam has a smaller base circle). i actually read that they boosted one guy's oil pressure quite a bit (think it was a moderator).
the oiling holes are also made differently as are the recesses for the oiling holes.
the pushrod cup is supossed to be of better design as well.
Old 05-03-2005, 04:13 PM
ZULater01's Avatar
The car has 45k miles on it. I have heard a ton of good things about the morels but money is tight right now so If I don't need them don't want to replace them, ya know.
Quick Reply: Stock Lifters with a G5X2
