What HP to look for out of tune tomorrow...
Hey guys. Tomorrow I am taking my '01 WS6 w/ M6 in to get it tuned. This past winter I installed the following:
AFR 205 heads w/ 66cc combustion chamber and 8019 spring upgrade
Comp cam w/ 228 in.dur. 230 ex. dur. .571 in. lift, .573 ex. lift, 112 LSA
Comp roller rockers w/ 1.75:1 ratio (makes lift ~ .588 in. and .590 ex.)
Comp pro-magnum lifters
Comp Hi-Tec pushrods 7.400
FAST LSX intake
FAST 90mm T/B
Stock injectors (have FAST 36# injectors but think they were too big)
SLP ceramic coated, polished stainless, long tube headers
SLP underdrive pully
Corsa catback system
I was just wondering how much hp to expect out of this combo. I am hoping for 430 rwhp or more. Think it is possable? I would like a good guess, so I can tell if the guy does a good job tuining it tomorrow. They will be using a dyno jet w/ LS1 edit.
FAST LSX intake
FAST 90mm T/B
thats a very nice set-up you got there!
ill guess your baseline will be around 390-410rwhp
and after alot of tune to smooth things out, and then going for power, id say you should be between 420-435rwhp...
let us know how you did!
good luck!
good luck!
