228/236 (.600,.600) crane cam
Old 05-05-2005, 04:29 PM
Z-286speed's Avatar
Default 228/236 (.600,.600) crane cam
What did you use to tune this cam, the crane tuner? Also, if anyone has sound clips, that would be great.
Casey
Old 05-06-2005, 12:11 AM
PREDATOR-Z's Avatar
This is what found on VINCI site:
041
DUR @ .004" 290*/ 298*
DUR @ .050" 228*/ 236*
LIFT.600/.600
OVERLAP 66*
LSA 114*
STROKER EXTREME
POWER RANGE 2700 TO 6500
TUNING & STALL CONVERTER REQUIRED
ROUGH IDLE
Apparently it is a stroker cam but that doesn't mean you cannot use it in a 346. IMO it will probably work best with a good set of heads.
I saw in a post that someone at VINCI is using this cam.
Perhaps you should call VINCI and get feedback on it.
Quick Reply: 228/236 (.600,.600) crane cam
