How does the MTI X1 cam stack up against newer grinds?
I know the X1 has been out for a while, and I've had it in my daily driver for over a year and a half... Thinking about doing AFR heads this fall and wondering if this cam is a good one to keep, or if I could keep similar driveability and gain some power by switching to a newer grind (maybe an f13).
I've liked the X1 on stock heads and will probably keep it unless any benefits could justify $400 for another cam...
I went with the Y1 from MTI and sold my X1. It`s aliitle tuf to tune with A4. MTI has her now finishing the final tune. David said she is driving great now. I do love the sound of my new cam verses the X1, but drivability is alittle harder now. Car in Sig Good Luck!
Originally Posted by JaSSoN
I like mine. I dont think its worth the change until I go bigger cubes.
I've heard some older design cams, for instance the TSP 231/237 just doesn't stack up against some of the newer stuff (maybe because of lobe design ?). I was just curious if the design of the X1 is old enough that it is leaving alot on the table for its relative size...
