Is my oil pump bad
Old 05-13-2005, 11:16 AM
sevanseriesta's Avatar
Default Is my oil pump bad
Well, I am not sure which is the problem. When I did my cam swap I have always had really good pressure between 30 and 50 at idle. I changed to a ls6 pump and now I get 10 to 15 at idle. It starts at 50 when it is cold and then goes to 10-15 when warm.
How do I know if it is the pump or the o-ring. Am I going to have to tear the motor apart to see.
Old 05-13-2005, 11:28 AM
zamboxl's Avatar
might be the o ring that is pretty low even for a cammed car. U dont have to tear down the motor just take out the main seal and u'll see the oil pump right there.
edit:: my mistake u gona have to take the timing chain out of the way first.
Old 05-13-2005, 11:30 AM
I did not mean tear down the motor just the front part........The same thing that we had to do when we put the cam in
conan's Avatar
My ported ls6 oil pump makes 70psi cold idle 60psi hot idle and 70 to 80 psi hot WOT. Did you get your shims for double roller in right?
Old 05-13-2005, 11:31 AM
777's Avatar
that's what mine makes...
Old 05-13-2005, 11:36 AM
zamboxl's Avatar
damn those some low #'s mine dips down to about 19 or so when it is super hot at iddle but never down to 10 or 15 are u guys running like a giant cam or something?
edit:: hey man is that jeremy out of tampa that did ur tunning??
Old 05-13-2005, 11:43 AM
rollinna65's Avatar
lowest mine has ever gotten on a hot day was 30-35psi so i'm willing to bet its the o-ring
Old 05-13-2005, 12:27 PM
conan's Avatar
If the triangle shaped shim is on backwards it will block half of your oil inlet port of the block.
