Changing Cam's. how big can i go??
Old 05-13-2005, 08:37 PM
SSLS1's Avatar
Default Changing Cam's. how big can i go??
ok well i am currently running a F14 232/234 .598/.598, i have Patriot 5.3 stg 2 heads, just wondering how big i can go without have ptov problems...??
Old 05-13-2005, 08:53 PM
99CamaroSS_'s Avatar
whats wrong with the f14??
Old 05-14-2005, 02:18 PM
SSLS1's Avatar
nothing is wrong it runs good im just to a point where i want to try and get more power, and i wasnt really impressed with the way the f14 sounds it doesnt really have a rough idle like people were telling me, my tsp 231/237 sounded alot meaner
Old 05-14-2005, 02:34 PM
Well if you want more power i suggest doing something different then just the cam. Why not Try the Fast 90/90 Setup you should see significant gains with that, Or why not get some spray. Just my .02
I would personally keep the cam/head setup you have and look to do something a little different.
Old 05-14-2005, 02:57 PM
bigdsz's Avatar
The guy that notched my pistons has a stock cubed Vette. The FAST 90/90 gained 3 HP on his Dynojet over the LS6 intake. Only worth it on big cubed engines.
Old 05-15-2005, 02:52 AM
SSLS1's Avatar
i have spray but i dont want to rely on it for power,
Old 05-15-2005, 02:58 AM
DietCoke's Avatar
you want more lope, turn your idle down 150 rpms
Old 05-15-2005, 05:43 PM
Firehawk441's Avatar
The TPIS modified LS6 intake and oval throttle body makes approx. 5-7 horsepower and torque across the entire rpm scale. It works best with head and cam engines and strokers. I have used this intake before on my old 383. I dynoed the car before and after the intake change . Also, I think the cam you are using now is fine. If you had a 112 LSA or lower, your idle would be bumpier. With an automatic, I would stick with what you have.
Old 05-15-2005, 07:24 PM
ss rally red's Avatar
What do want results or something that sounds "meaner?" Why dont you try a VTEC system YO?
