which cam
which cam
Im deciding between these two cams from thunder racing give me your pro and cons for each.
Thunder Racing Custom Camshaft - 230/236 .590/.598 112 LSA 2400-6800 RPM Power Band. Excellent mid-range & high RPM power. 3200+ stall, 3.42+ gear, computer tuning required. Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended. 230/236 .590/.598 112 LSA
OR
Thunder Racing Custom Camshaft - 224/224 .563/.563 112 LSA 1700-6600 RPM Power Band. Excellent mid-range & high RPM power. Requires computer tuning on automatic transmission cars. Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended.
OR
What do you want from the car? I assume the headers listed under next mod in your sig are going in with the cam. You getting heads too? I'd try to match the cam to the heads.
Regardless, between those two I'd vote 230/236. Of course, you havn't given us much to go on...
Im looking for a good mix between power and driveability the heads won't be for a while the cam is coming this week. the headers are in the works and Im ordering 4.10s with the cam.
The TR 224/224 is a great cam I ran it for a while and was very happy with it, but these days bigger seems to be better. I've got a CC XER 228/230 and wish I would have gone even bigger. I'll probably continue to get bigger until the car is no longer streetable.
so with a good tune how would the 230236 be as far as driveability. I really want to be able to use the car like i do now a lot of street driving and ac use in the summer. I do city and highway driving too.
Im looking to do headers, 4.10s, heads, and maybe a shot of nitrous. Will these eventual upgrades have an effect on which cam I should get or will both work well with this combo.
I would definitely go with the 230/236 if not larger. I put that cam in my car three weeks ago and it drove ok untuned (6speed). Got most of the tuning straightened out today and it drives great. I spent an hour in traffic on the way home from the shop with no problems. 4.10s would be great but I have 3.42s now, but not for long. Good luck.
Rob
Rob
