Best rocker arms out there?
I'm needing some to replace my stock rockers with the new cam and im not up to date with the ls1's latley. What i want is a rocker arm kit that will work with my cam only setup that i won't have to worry about and will be a direct replacement without having to machine them. Right now i'm leaning towards the comp. magnum rockers 1.7 or is there anything as good or better for a decent price? The comp. rockers are a little pricey but they are reliable.
Restricted User
Whats wrong with the stockers? I havent seen where any others are lighter, or beneficial yet. Everyone jumped on the YT bandwagon and then what happened, heavier and more money spent for a part that only offers "insurance" against stock parts breaking. If chevy uses the stockers for circuit racing then I feel comfy with them holding up for daily driven 10sec pleasure car.
My opinion is that there is no better rocker arm choice than the Crane "Quick-Lift" roller rockers. They can be bought bare or in a complete kit that includes beefier studs, adjusters, guide plates, and special length, heavy-duty pushrods. They are available in 1.70 (actually 1.72) and 1.80 (1.82) ratios.
The 1.70 versions have a ratio of 1.78 when the valve leaves its seat, drops to 1.72 at ~.300" of valve lift and maintains this till the valve again reaches ~.300" as it closes, then goes back to a ratio of 1.78 till the valve is again seated.
I swapped out a set of SLP 1.85 rockers for a set of the Crane 1.80 roller rockers and, in spite of the fact that I lost ~.010" of valve lift because of the slightly lower ratio, I gained 10 rwhp and 8 rwtq with the Cranes vs. the SLP's.
http://www.cranecams.com/?show=newPr...516c5051c3d658
Jesel rockers are not what im looking for. It's to much trouble going with spacers and having to spend more money on different pushrods when others will work without all that crap.
1 Post
Stock rockers are sure nice for most applications...
Some of the aftermarket pieces are too heavy at the valve...
Use J2K Jesels if you are going insane but the stockers sure perform well...
Ed
Ed
The stockers with the Harland Sharp bearing mod ($250) are good for 99% of applications, then look at the Cranes and the Jesels according to your budget.
Ben
Ben
Ed
Ed
http://www.vincihighperformance.com/superwebdeals.HTML normally $669.00 but right now there's a GP going on for $635.00 here: https://ls1tech.com/forums/sponsor-sales-specials/323171-gp-cams-rocker-pkg-valve-spring-pkg-vhp.html
you have to use shorter pushrods with these rockers. so, either way, you'll end up buying all the parts in the kit. chrome moly pushrods, screw in studs, polylocks, and guideplates.
http://store.summitracing.com/defaul...=egnsearch.asp 399.99 for rockers only at summit racing. but you'll have to wait until june before they'll ship out to you.
Ed
Ed
Originally Posted by Beast96Z
Stockers are fine in most motors the sponsors build, so there ok in mine.
LS1 Tech Administrator
Originally Posted by gollum
Why no roller tip? LS7 cam has .591 overall lift with 1.7 rocker ratio.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
A cam with a lift of .591 @ valve does sound radical, especially with 1.7 rocker ratio and 210 degrees duration @ .050 lift. But 1.7 (type error maybe?) is what I read from a good source.
I spent the last month looking into this and, I just bought the Crane VHT or "quick lift" 1.8 rockers from Joe Vinci. As mrr23 said, Vinci has a price break on the rocker kits either 1.7 or 1.8 and he is also giving some price breaks on cams and springs, etc.. The concept of the VHT Crane rockers makes sense and I wanted to try to add a few easy HP w/o doing a cam right now. I can't wait for them to get here so I can put them in. Call Joe Vinci and talk to him.
