cam and rocker ??????
Old 05-19-2005, 12:26 PM
HASTINGSRJ's Avatar
Default cam and rocker ??????
OK, some one was telling me that I need to get new rockers to run my cam with my stage II heads??? The cam specs are in my sig. He was saying that I need to get 1.7 rockers. But arent stock rockers 1.7's on a 2000 LS1???? Any feedback on this??? Thanks
Rob
Old 05-19-2005, 12:31 PM
HASTINGSRJ's Avatar
or better yet, how much lift can stock rockers handle????
Old 05-19-2005, 12:37 PM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
Stockers are 1.7 and they are great. Keep 'em. Tell your source of info that he's wrong.
Old 05-19-2005, 12:43 PM
HASTINGSRJ's Avatar
Awesome, I was worried for a second there. I actually just called Thunder Racing, and he said the stock rockers will hold. Thanks for the info.
Rob
Old 05-19-2005, 02:54 PM
ls1charged's Avatar
your source is a moron
Old 05-20-2005, 05:37 AM
XTrooper's Avatar
They're "great" if you don't mind the very real possibility of finding needle bearings in your oil pan. I'm sure you're aware that a good number of stock rocker arms have failed and come apart.
Rob,
You certainly don't need new rocker arms, but, if you have the money, it's not a bad idea to get aftermarket ones.
Old 05-20-2005, 07:43 AM
!LS1 11 Second Club
Rob,
It's a possibility of course, but they hold up well.
Do a search and see? I read the internals forum every day. I think I'd be concerned if I read more threads about them failing.
BTW, I've seen enough threads with people's dyno graphs going all erratic past 5500 rpms due to certain aftermarket rockers.
Old 05-20-2005, 11:42 AM
XTrooper's Avatar
Yeah, they can happen! However, there's a fix for every problem.
Old 05-22-2005, 09:50 AM
HASTINGSRJ's Avatar
Thanks for you input guys. Now all I need is some lifters, and I am set to do the swap
Old 05-22-2005, 10:10 AM
!LS1 11 Second Club
Stock lifters are good too!
Old 05-25-2005, 06:25 PM
HASTINGSRJ's Avatar
But new stock lifters, or the ones that are already in there?????? Was kinda wondering about that..since the cam is new....
Old 05-26-2005, 07:37 AM
!LS1 11 Second Club
The ones already in there are good.
Mileage on the engine in question?
Old 05-26-2005, 08:17 AM
PREDATOR-Z's Avatar
Yess stockers are good, but if you're taking the heads off and running bigger cams, might as well put replacement Comp 850-16 or Crane ones (better than Comp but a little more expensive). There is also Morrels of course.
Most stock lifters fail due to improper preload or with cams that surpass their designed parameters.
Old 05-26-2005, 05:28 PM
HASTINGSRJ's Avatar
Yeah, I was thinking since I am going to have it all broke down, might as well replace them while I am there. The motor has about 81k on it now....and still running really strong...other than a little tuning. But that will come after the install. I am just going to go with a set of stock lifters......the cam going in is in my sig, and a set of Absolute stage II heads
