Opinions on this cam, HP & tuners results.
Looking for an opinion on a dyno tune.
I DID tell the tuner that I don’t bracket race.
I DID tell him that I liked to drive fast for extended periods.
I DID tell him that I liked to WOT runs occasionally.
I DIDN’T tell him that I was going to be driving the Silver State Classic or other road race.
Regardless, he said after he tuned the car that he was conservative on the A/F ratio & timing at high rpm to bring down CHT for extended runs to provide a safety margin for the heads, but that I lost a minor amount of horsepower.
On the dyno, the run yielded:
Max horsepower 371 @ ~5500 - 6000rpm, MAX torque 342
Q I think that he was too conservative. What do you think?
Also the idle seems a bit high @ 900 rpm, and also rougher than I expected.
As rough as the Hot Cam guys describe their cars with their 112° lobe separation.
With my 144° LS & Comp Cams grind, I expected a more stealthy idle.
Q Could the tuner have misprogrammed the idle?
Info on the car:
2002 LS2 manual transmission.
Ported Throttle Body, smooth bellows, SLP Underdrive Pulley 180° thermostat
Dynatech SuperMAXX Header System {High-Flow Catalytic Converters & all oxygen sensors present.}
Comp Cams shaft installed:
GRIND #: LS1 3767R /3753R HR114.0
GROSS VALVE LIFT .532 .535
DURATION @ .050 220.00 224.00
LOBE SEPARATION 114.0
ROCKER ARM RATIO 1.70
Coolant fan temperatures: Primary ON @ 200° OFF @ 190°
Secondary ON @ 210° OFF @ 200°
PCM Rev Limit set to 6600rpm, Shift @ 5800rpm
Premium Fuel Only, prefer Mobil 93 octane.
A/F ratio 13.1 to 5000rpm, 12.8 above 5000rpm.
Timing: 22° Total Timing
Curb Idle @ 900 rpm
Info on the car:
Curb Idle @ 900 rpm
1) Dyno runs can vary +/- 10 hp on any given day
2) 22* total timing does seem a bit conservative
3) I felt the same way about my "rough" idle for about a week (after the install). The more I drove the stealthier it became. It's been about a year now, and about 30 seconds after startup it runs like stock (a little sewing machine sound).
Did you do anything to the TB to help your idle?
Thanks!
Info on the car:
Curb Idle @ 900 rpm
Info on the car:
Curb Idle @ 900 rpm
t-stat to get h20 temps down. Then bump up timing. I'd also recommend SVO
30#. Doing alot of hi-speed running going to tax your injectors. I have these
mods on my 2002SS & woke up my car. 93 Octane is good insurance, tho I
can,t get it in my area. Also if legal a good h20/injection setup would help with CHTemps and aggressive timing. I have one on my car and gained about
30hp/tq.
