Should I go 408 0r 418????
Is there anything wrong with doing the bigger crank and stroking to a 418? I thought the bigger the stroke the better.
Also I bought the F13 cam thinking I wasnt going to stroke the 6.0L,should I change?
Thanks,Steve
Thanks,Steve
Originally Posted by JZ'sTA
Price is almost exactly the same.
You could go real crazy and do a 4.125 stroke with a 4.060 bore.
What is that a 422?
And yes you will defentially benifit from a Larger Cam.
What is that a 422?
Yeah, a 427 stroker for the same price of a 408...
I wonder if there are many of them running around here. I don't remember seeing one on LS1Tech.com.
There were 2 that I found.
Here are the links.
https://ls1tech.com/forums/showthrea...&highlight=427
Here are the links.
Shorty Director
There you go.
A non sleeved 427.
I guess I could have ran the calculator on that but I got lazy.
A non sleeved 427.
Originally Posted by VINCE
I think that is more like a truck motor. Stroke higher than the bore would cause your hp to peak early, but you would have monstrous tq. To me that is not much of a race car. You would need a HUGE cam to offset the hp peaking earlier. I like my combo. Revs just like a big cammed 346ci.
I totally agree Vince.
I would much rather have the larger bore then the larger stroke.
I was just giving some other idea's.
I have a similar combo as you using a 4.040 bore and 4" stroke which equalls 410 cubic inches.
Stage 3 TEA heads on the way. My cam is smaller as I am only running a 242/246 duration camshaft.
Thanks guys for the suggestions.... I spoke with Allen at Futral today. He said he is not a fan of the longer stroke 418. He liked the bigger bore 418 sleeved but said the longer stroke was harded to get right (not quoting him though)......but I will go with a 408 and a 243/246 112* cam.
Steve
Steve
