Biggest cam with milled heads?
Old 05-28-2005, 03:08 AM
Dustin 98TA's Avatar
Default Biggest cam with milled heads?
What is the biggest cam anyone has run with heads milled .030 and larger valves? I have 2.055 intake valves and shaved heads running a TR224, but I want to go bigger. Im leaning toward the FM11. Anyone have any experience with this setup?
Old 05-28-2005, 07:25 AM
C5 Purple Haze's Avatar
I asked Allan Futral the very same question. My heads are shaved .033 with 2.02 int. 1.57 ext. valves. Allan told me the F11 on a 114+4 would fit. Give him a call I'm sure he can give you the needed advice.
Old 05-28-2005, 05:44 PM
Are you running the FM11 now?
I talked to Allan the other day and he seems to think it will be OK.I guess im just being a little cautious and trying to see if anyone has run this type setup before.
