Opinions on new setup
I decided to go with a different setup so im wondering what you guys think.
F13 Cam +4 (Should I stay at +4 or degree it a little bit) I do a lot of street racing and run at the 1/8 and 1/4 track maybe 1-2 times a month. I run m/t drag radials around town. I also like to roll race
PP ls6 Heads (hand finished by ffhp or Bo if he gets time)
I shouldnt have a problem with pv clearance right?
vig 3600 mult disc converter
Jet Hot headers and Y pipe (both coated)
Magnaflow exhaust
85mm Maf and lid
TnT wet shot (150)
Stage 2 dry shot(50)
As of now I dont think the 90/90 setup is worth the extra money besides I need to be saving up for the transmission build up and the 12 bolt.
With these heads I can go from 11.0 to 11.8 compression with different size gaskets. I think I want to run about 11.3:1 any suggestions on this? Im from MS so it does get hot here but im running 28* at WOT w/o issues as of now. During the winter it held 30*. We also have 93 octance here.
I have hptuners so I can adjust timing depending on the temp out so is it better to go w/ higher compression or more timing? Does it work like that?
I run 12.3 @ 111 1.78 60' as of now. What do you think I can do with the h/c? Im hoping for low 11's once I get my 60' down to a 1.6. I know theres more in it right now because Im spinning pretty good even w/ the 1.78. With the 175 shot I would like mid 10's.
I plan to give it an initial tune then drive it down to allan at FMS so he can work his magic
Any advice just let me know thanks
Magnaflow exhaust
85mm Maf and lid
TnT wet shot (150)
