off ground stroker crank rod bearings
Old 06-03-2005, 07:49 PM
SSPerformance's Avatar
Default off ground stroker crank rod bearings
well i went to go put my pistons and rods in and i bought a set of ls1 rod bearings and notice when i compare them to what was in it for rod bearings (Clevite 77 CB745H) which is a SB Chevy 327 Race Rod Bearings.they where alot bigger so i looked up the # and it turns out this crank has smaller rod journals i take it......
Old 06-03-2005, 09:52 PM
strokedls1's Avatar
I had my crank offset ground to a 2" journal on my lunati crank. Just have to buy a radius 2" bearing. Do you have a stock offset ground crank? I don't get what the question is.
Old 06-03-2005, 10:42 PM
xssive's Avatar
Thats the whole idea behind offset grinding. You get the extra stroke from the rod journals being ground down....
Old 06-04-2005, 12:09 PM
Futral's Avatar
Lunati is the only place for the 2.100" to 2.00" bearings made by King bearings.
