broken valves?/
Old 06-08-2005, 07:34 PM
ninobrn99's Avatar
Default broken valves?/
What are some symptoms of a broken valve or bent pushrods or any problems with the heads other than the gaskets. Im trying to figure out why my car is running like ****! Its eating up gas like a **** and I have no power where I used to. I have no low end tq anymore. 3rd and 4th gears are weak, when they used to be very strong. Before it was tuned, it still ran good, I got it tuned a few days after and ran great. Now, 6 months later its running like dookie. A little help would be nice.
Nino
Old 06-08-2005, 10:20 PM
ninobrn99's Avatar
someone's had to have broken a valve and had symptoms...come on tech
Old 06-08-2005, 10:52 PM
2K2WS6TA's Avatar
Bent a valve in my IROC, and the symptoms described in your first post were what it was doing, plus the ticking/clicking noise. Have you over revved it, what makes you think it's in the valvetrain? Might be time to take off the valve covers and take a look
Not going to say definately valvetrain, but if everthing else has checked out, that'd be my next stop
Old 06-08-2005, 10:56 PM
ninobrn99's Avatar
ive checked the driver side and it kinda looked like one of the pushrods was slightly bent...very slight. I still need to check the passanger side. I dont think that Ive over reved it. I wont know till i finally pull the heads, but I need to get some gaskets and studs first.
Old 06-08-2005, 11:36 PM
2K2WS6TA's Avatar
If you still suspect a broken valve, a leakdown test could help determine what cylinder it is (if a piece of valve is missing or the stem is bent)
Old 06-09-2005, 07:49 AM
ninobrn99's Avatar
which is easier? doing that or pulling the heads?
Old 06-09-2005, 04:50 PM
ArcticZ28's Avatar
Compression test is easier, but chances are that you're gonna have to pull the heads anyways. So do a compression test first to see which cylinder it is (b/c you may not be able to tell with the naked eye) and then pull the heads.
