Cam Info ALREADY READ CAM STICKY
my question is with the following mods should i run this big of a cam. i am looking for around 400 after cam and good streetability.. Cai, Custom Exaust with x-pipe, SLP mass air, and Stainless Works longtubes. The cam suggested to me is 230/224 .575/.563 111 LSA . and if i go with this cam is this going to accomplish what im looking for after a tune.. any help would be great and also if anyone is running a setup similar numbers would be great..
Are you aware that most people have nothing but problems with different MAF's? What year is the car? If 98-00, do you have an LS6 intake? What tranny? I assume it's an M6...stock gears? Do you have a lid?
Go bigger...if you want to make sure to go over 400 rw. You can drive the monster cams everyday with good tuning. I went 230/236 .591/.598 and wish I had gone with a larger grind. It drives great, pulls like a **** and with a ported TB I will go over 400 for sure. BTW, this is if you are a M6. A4, do some more research.
Rob
Rob
