.080 head gasket
Old 06-11-2005, 04:19 PM
JZ'sTA's Avatar
Default .080 head gasket
Would there be inything wrong with running a huge head gasket like a .080 size?
If I toss on a set of LQ9 heads and a .080 head gasket it takes me to around 9:1 compression.
Is there any negative in using a thich gasket to lower compression?
Old 06-11-2005, 04:29 PM
BBADWS6's Avatar
Gives you more of a chance to float your heads, expecially if you are runing a power adder.
Old 06-11-2005, 04:59 PM
PREDATOR-Z's Avatar
Not to mention it kills your quench and increase chance of detonation.
Old 06-11-2005, 11:04 PM
Beast96Z's Avatar
You also better your chances of blowing the gasket because it is so much thicker. Deffinatlly not the route I'd go with forced induction. Also, like predator said, quench would be off which would increase you chances of detonation.
