5.3 heads milled 30 thou.
Old 06-14-2005, 05:19 PM
n2o
n2o's Avatar
Default Milled 5.3s. What are my options?
My 5.3 heads are milled 30 thousandths and I would like to upgrade my cam. How big of a cam can I go? I would like something like an fm 13. I'm tired of my 224.
Old 06-14-2005, 07:45 PM
66deuce's Avatar
you will probably have to flycut the pistons with the F13 or similar cam.the 5.3s have a lower valve drop than 5.7 heads(about .030).no matter what cam you go with,check your piston to valve clearence.
Old 06-14-2005, 08:54 PM
n2o
n2o's Avatar
This is going to be more complicated than I wanted, I suppose.
Old 06-14-2005, 11:07 PM
flippincamaro's Avatar
hey i run a .591 .569 lift cam with 5.3 heads shaved .020 and it seems to be fine but my pistons did notch theirselves before with the old valves in my other heads. not sure how much though
