what cam for LS1 383?
i just installed a 383 into my trans am. i have in it right now the small comp xe-r 224/224 .581/.581 lsa114. what would be a good cam to replace it with for N/A performance but when i spray the 150shot it will liek it to just throw up some sugestions yall
Originally Posted by Wickid Z
how bout the T-rex or the magic stick?? theyre both really aggressive cams with a traditional split for spraying. but....how's your ptv clearance now with the 224 cam??
im not to sure on the ptv clearance the cam was first installed by me into the stock motor then i lost a valve spring and a valve hit the top of #1 piston and well teher was a hole in it. so i had HPE build my 383 and i reused the 224cam. i know we decided to go with 8cc dish and 2cc valve relifs becaus ei was using stock heads i was just seeing if anyone had any good ideas on what i should run and still be very streetable
Originally Posted by PREDATOR-Z
Do you want max effort or tame?
G5x2/x3 or FM9 are good street/strip sizes with very friendly manners in a 383
