Lifter noise ,Clicking,6.0l,, HELP !!!!
I bought a 6K mile Escalade motor ,,Converted it to F body ,,, I installed a Comp cam & springs,, started engine and have rocker arm clicking{ stock roller lifters], Called Comp and they said change lifters,[must be weak]After spending $400 bucks for bolts, 6.0l gaskets,lifters ,it is worse now than with the stock GM lifters,, I checked push rods the first time and again ,, Please any Help!!!!!!!!!!!
So you replaced the stock lifter with comps and it's worse?
Assuming you have good oil pressure you need to check your pushrod length and preload. This sounds like an easy fix, just be patient, do your checks and you'll get it solved.
