How will PtV clearance change between these 2 Cams?
Let's say a cam has the following specs:
Cam "A": 224/224 XE-R Lobe, 112LSA +4 Deg Advance on 108 ICL.
Using Cam "A" and a set of .030" milled LS6 heads (2.02/1.57 valves), it yields a piston-to-valve clearance of .060".
Now, how will the PtV clearance change - that is, how much more PtV clearance will there be - with Cam "B" (below) and using the same .030" milled LS6 heads (2.02/1.57 valves)?
Cam "B": 224/224 XE-R Lobe, 114LSA +2 Deg Advance on 112 ICL.
Any additional information needed to better answer this question more accurately?
TIA........
TIA........
If you have .060" now with the INTAKE valve on a 108 icl, then retarding it to a 112 icl should increase the clearance on the intake and decrease it on the exhaust. How much? Couldn't tell you for sure, but 4* difference is probably only .020" or so. Call Comp and see if they can give you an idea.
Originally Posted by Beast96Z
He's asking how much he'll gain if he goes from 112+4 to a 114+2. In a basic test that I did while assembaling my motor, 1 degree of advance changed the clearence about .007". So you'll gain about .014" just by taking away 2 degrees of advance. I don't know how much the LSA will change it, but you will gain more clearence with the 114.
114+2, 112* intake centerline, 226* exhaust centerline
You're losing 4* on the intake side going from a 108icl to a 112 icl, so if you -theoretically- gained .007" per degree then you'll gain .028". That .007" sounds fairly close to what I saw when I degreed my cam in, but keep in mind EVERY lobe will be different somewhat for that value.
On the exhaust side, you'll be 6* retarded with the 114+2 vs the 112+4 so that -should- give you more clearance on the exhaust also.
Hope that helps.
