COMPRESSED Head Gasket Thicknesses - MLS / Graphite
Need some clarification on the compressed-thicknesses of various GM-OEM LSx 5.7L head gaskets. Its pretty clear what's available from FelPro, Mr Gasket, or Cometic, but concerning OEM-GM gasket compressed-thicknesses, I'm now confused as hell.
- What is the stock head gasket used on 2002 5.7 LS1s? Graphite or MLS?
- What is the stock head gasket used on all 5.7 LS6 motors?
- What year did GM start using the MLS gaskets on LS1 motors?
- What is the COMPRESSED thickness of the MLS gasket?
- What is the COMPRESSED thickness of the graphite gasket?
There's so much conflicting information in various past threads (many intensive searches), including in our "sticky" above on the Compression-Ratios - for every posting or thread I see stating one thickness, I see another with different info.
PaceParts lists the MLS compressed gasket thickness at .060". Most other threads list the MLS compressed at .054" or .052". And even in our sticky above, there are individual postings that state the MLS has a compressed thickness of .060", .054" and .052". Can't be all three....
Hope to get some definitive clarification on this....! THANK-YOU!
The MLS gasket should have a compressed thickness of .052. The older graphite gasket should be .040 compressed. The graphite gasket was used from 97-98, then GM switched to the MLS from then on (and still uses them for the LS2).
Originally Posted by ArcticZ28
I had graphite gaskets on mine and it's a 99.
02RedHawk - I apologize for any confusion. Honestly, I would call a sponsor for the actual compressed thickness of the graphite gasket. I do know it is less than the MLS.
.060" for the MLS
.053" for the graphite
100% sure of that. Have measured them myself.
Graphite was used on 97-01, all LS1's AFAIK. My '01 had graphite. Believe the MLS came out in '02 model years on LS1's.
Thank-you 1fastWS6.
So, kinda taking this thread now to more of a heads-question, provided that we're all in agreement that the gasket-thicknesses are correct (MLS is .060", Graphite is .053").
Would it be recommended to take .010" off my set of LS6 heads -and- use a .045" Cometic gasket (net reduction of .025"), instead of just milling .025" from the heads and using the stock .060" MLS gasket? (that is, I should then have my quench a bit more optimal, and likely produce more power at the same CR?)
Cam is a 224/224 .581" 114+2, heads and cam going on an '02 Firehawk. No PtV issues with either of my two options above; just looking for which would be "better" - thinner gasket + slight milling, or more milling and stock gasket.
