? on makers of 160* thermostats
Old 06-23-2005, 12:59 PM
shouldaboughttheZ's Avatar
Default ? on makers of 160* thermostats
I am fixing to order my 160* thermostat. I am down to Hypertech and SLP.
I have read a few people having problems with the Hypertech not working right out of the box. I know any company has problems with their products sometime.
Opinions are welcome.
So my question is:
Would you buy the Hypertech 160* thermostat for $45.99 or the SLP for $50.70?
Old 06-23-2005, 01:23 PM
tomaSS's Avatar
I have the Hypertech and it works just fine.
Old 06-23-2005, 02:33 PM
PREDATOR-Z's Avatar
Some people are confused that they will read 160* temps after putting a 160* thermostat.
It only means that the thermostat will let coolant into the motor once it reaches the 160* mark. Temp readings might be slightly less. LS1's operate at max efficiency over 200* anyways. Cooler is not better.
Old 06-23-2005, 02:59 PM
Rebelord's Avatar
well, when its on average of 115 out here in yuma, az. thats ambient air temp too. not the actual temp on the road or ground here. so, having a 160* stat is quite useful in hot temps. now, if its a colder enviroment then yea, stock would be better. I see that you location says your in Dubai, i've been there. I know it aint cold and quite hot. So, you would probally benifit from a cooler stat.
Ski
Old 06-23-2005, 03:00 PM
so you are saying to leave the stock in there? I was under the impression that cooler was better to a point.
Old 06-23-2005, 03:09 PM
PREDATOR-Z's Avatar
No I'm saying that if you put a 160, you'll never see 160* temps.
By opening sooner, you're cooling your motor sooner.
Old 06-23-2005, 03:12 PM
I new with the 160* that I would see temps between 180* and 190* while driving.
Old 06-23-2005, 03:16 PM
PREDATOR-Z's Avatar
It depends on ambient temperature,& cruising speed.
Usually you have to adjust your fan activation temps also.
And use a real temp guage, that stocker is fucked
Old 06-23-2005, 03:24 PM
I agree about the stock gauge, it does suckass!
My tuner can adust the fan temps for me.
Old 06-23-2005, 04:35 PM
bigdsz's Avatar
Anyone that believes that SLP manufactures their own thermostat is nuts , I will almost guarantee you that SLP is Hypertech.
Old 06-23-2005, 04:40 PM
5.3 racer's Avatar
bought one off of ebay, Murray Plus brand part#37960.
Old 06-23-2005, 04:42 PM
2xLS1's Avatar
All the hypertech 160 t-stats I've seen have Moto Rad cast into the housing. They probably make all of them. http://www.motoradusa.com/products/t...ement/pic.html
Old 06-23-2005, 05:19 PM
Well I guess I will keep the $5 difference and get the hypertech.
Old 06-23-2005, 05:22 PM
PREDATOR-Z's Avatar
I've had one in my Z for 3 years now. No problem
Old 06-23-2005, 05:47 PM
gwj
gwj's Avatar
Location: Live Oak, FL - in the woods where the creatures lurk.
If you want to spend $0 and have a 160 thermo, you can pull it apart and shim it yourself. I did this probably 3 years ago. Once you pull it apart you will see an opening where part of the thermostat travels while opening/closing. You can drop a BB in there and essentially make it open at around 160. (I actually lopped off the end of a machine screw with a dremel myself)
Anyone else remember this? It was one of the "free" mods floating around about 4 years ago.
Old 06-23-2005, 06:54 PM
02RedHawk's Avatar
Only works on a few select years of 'stats. My '02 t-stat didn't work using this method. (yes there was a t-stat change in design in '00? '01? I forget offhand....) I experimented with 4 t-stats, 3 of design "a", and 1 of design "b". Only the earlier years' t-stats could be modded like this.
Old 06-23-2005, 09:42 PM
I have seen this write up on ls1camaro.net. Didn't think I wanted to do that, be my luck I would screw something up.
Old 06-28-2005, 11:15 AM
Just to let you guys know, I got it in today. Stamped right on the housing is "MotoRad Germany".
Old 06-28-2005, 11:33 AM
cyphur's Avatar
I've had a SLP thermo layin around for about 2 yrs now, MotoRad Germany is clearly stamped on it.
Old 06-28-2005, 12:32 PM
robertbartsch's Avatar
Yeh, I did the free mod shimming the stock thermostat abuot 4 years ago and it worked fine.
Later, when I swaped the heads and cam I bought a new stock unit...
A cooler thermostate does not mean more power; if that were the case no thermostate would be best...
Quick Reply: ? on makers of 160* thermostats
