Help idnetifying Crane rocker arm install parts
Old 06-23-2005, 11:42 PM
SVC707's Avatar
Default Help idnetifying Crane rocker arm install parts
it came with the two on the left, and then 16 of the one on the far right. are the two on the left used for the initial install process where it says to torque down to set screw to 25lbs and then the adjusting nut and arms stud to 22lbs
then once you have them tightened. you'll remove the allen set screw in the middle, then the instal nut with with the allen leaving just the the stud to mount the arm onto, after 6 hours of allow time?
Old 06-24-2005, 12:30 PM
kenp's Avatar
You are correct. The two on the left are intended to be used to torque the studs only.
Old 06-24-2005, 12:41 PM
SVC707's Avatar
thats what i wanted to make sure of. gonna torque down the studs today after work and let them sit over night and install the rest tomorrow or sunday. sucks gonna have to take the 600RR out of hibernation.... wish me luck on tryin to figure out how to tighten and adjust the arms down. like i read the instructions look deceiving but is actually not bad just time consuming
Old 06-24-2005, 11:54 PM
kenp's Avatar
You shouldn't have any problems. Just read and follow the instructions. The most current instructions are also on the crane website. Keep track (written) of the number of times you make the 1/4 turn adjustments so you aren't second-guessing yourself as you're bolting down the valve covers. The one thing I didn't find was a torque setting for the lock screw. I just buttoned them down as tight as I could. When you start it the first time it will click and clatter for several minutes. Don't get disturbed by it. The lifters will readjust and get very quiet.
Old 06-25-2005, 12:41 AM
gmblack3's Avatar
Must of got lucky here, no noises on the first startup.
Just take your time, you will be fine.
Old 06-25-2005, 01:41 AM
SVC707's Avatar
im guessing it supposed to be pretty hard to get the full 1 1/2 turns on some of the springs be it's in the down position... if anyone reads this soon i hope it's ok as i have one more to go...
Old 06-25-2005, 02:07 AM
SVC707's Avatar
let me know if this looks right to you guys. i got six turns out of them making the 1 1/2
Old 06-25-2005, 05:35 AM
eallanboggs's Avatar
The Comp Pro Mags don't come with those extra polylocks. Too bad you don't have see thru rocker covers to show off those rockers. Keep track of which ones you have done and go step by step using the Crane tutorial. Pulling the plugs makes turning the crank easier. Tighten those sets screws down real good.
Old 06-25-2005, 07:31 AM
XTrooper's Avatar
HAHAHA That crossed my mind as well. They were so pretty I hated to hide them under the valve covers!
Old 06-25-2005, 08:18 AM
SVC707's Avatar
they are all about teh same i torqued them down to 22lbs too on the set screws. im just wondering if thats about how tight the set screws, how much thread dint go in. but i also thought different size cams will prolly look different?
Old 06-25-2005, 09:03 AM
gmblack3's Avatar
We tightened the set screws down to 15ft-lbs. You should be fine.
Old 06-25-2005, 10:49 AM
SVC707's Avatar
Im being a lil woose dint want to finish the install last night and start it up but ill do it when i get home and see how it goes... Im stuck at work
Old 06-25-2005, 04:03 PM
mrr23's Avatar
why are you stopping at 6 1/4 turns?? you are supposed to do 8 1/4 turns with #8 tightening the lock nut at the same time.
Old 06-25-2005, 04:06 PM
SVC707's Avatar
from your post on my other thread and quoted from vinci
"You must rotate the rocker nuts, in this manner a full 1 and 1/2 to 1 and 3/4 turns, so keep an accurate count of the number of times you make 1/4 turn adjustments"
Old 06-25-2005, 04:13 PM
mrr23's Avatar
will look into that part of the instructions. but it's supposed to be 8 1/4 turns in total. on the 8th and final turn you tighten the jambnut to the point where it bottoms out. then with the qrench and allen wrench you turn the last 1/4 turn. this sets the correct preload and will securely tighten the locking nut.
Old 06-25-2005, 04:31 PM
mrr23's Avatar
here's the link right off crane cams site on adjusting LSx rocker arms. http://cranecams.com/pdf/438e.pdf
Originally Posted by crane instructions
Now, tighten each rocker arm adjusting nut 1/4 turn. Allow the lifters to bleed down for 15 minutes. Repeat this procedure 7 more times for a total of two full turns. be sure to allow 15 minutes bleed down time after each 1/4 turn.
in both instructions it says to tighten the setscrew while holding the adjusting nut still. but, by turning both at the same time on the 8th and final turn, it will ensure the setscrew will be extremely tight and not back off. you can't always get it tight with an allen wrench. those with allen sockets will be able to put more force on the setscrew.
Old 06-25-2005, 04:41 PM
SVC707's Avatar
well ima try and get a couple more turns out of this but dayam its like the allen lock will barely even be sitting in the adjuster nut. its already pretty hard to turn the rockers that are in the down position. maybe itll be alil easier since it sat over night but well see.... one says this one says that... i think ima try and get one more 1/4 turn to get the 1 3/4 i use a allen socket on a torque wrench.. gotta love snap on
Old 06-25-2005, 04:48 PM
mrr23's Avatar
yeah, i think the webmaster just hasn't updated that page on vinci's site. i have an email into roger vinci about it now. what's concerning me is in your pics, the setscrews are above the adjusting nut. looking at the pics i have from doing it on my wife's cars, i can't quite tell if mine are that high out of the nuts or not. and it's been awhile since i did them to remember. when you do the 1/4 turn, you make sure it's like going from 12:00 to 3:00 right?? just wanting to make sure you are getting it done correctly. yes, some will be harder than others because you will be pushing the springs down. but, not difficult. here's the pic of mine. granted not as close as yours. so, it's hard to tell.
Old 06-25-2005, 05:01 PM
SVC707's Avatar
that was my main concern but yeah i made sure it was 1/4 turns be it this time to that where ever i had enough room. but im also thinking the cam profiles can make a difference in the amount of adjustments too?
Old 06-25-2005, 05:07 PM
mrr23's Avatar
cam profiles make no difference in adjustment procedure.
