Ls6 Heads???
Old 06-24-2005, 01:51 PM
stroked67camaro's Avatar
Default Ls6 Heads???
i got a F*CKED up set of heads that are CNC ported from a friend of mine and they are supposedly LS6 heads. i am wondering how you tell??? i know to look for casting #s but which ones??? here is what i got:
in the rocker valley it says: 1256 & 4243 on the combustion chamber side it says 02 circled and 5.7
any help is VERY appreciated...THANKS!!!
Old 06-24-2005, 01:55 PM
PREDATOR-Z's Avatar
There is your answer 243 (LS6 casting)
Also on the outside, bottom right hand next to the first exhaust port (243)
Old 06-24-2005, 01:56 PM
zamboxl's Avatar
243 is the ls6 heads i believe. whats wrong with the heads?? maibe the cnc fucked them up or something.
Old 06-24-2005, 02:06 PM
heres whats wrong with them...the face of the exhaust valve BROKE off the stem and BEAT THE SH*T out of the cylinder and the head and the piston. the heads is pretty messed up.
Old 06-24-2005, 02:31 PM
JZ'sTA's Avatar
Holy Shat....
Old 06-24-2005, 02:46 PM
what would you say they are WORTH??? im gonna have to fix the combustion chamber and have it re CC'd to match the other cylinders put a seat in it at least one guide im gonna have the heads cut for bigger springs while im at it and new springs...
WHAT WOULD YOU GIVE FOR THEM???
Old 06-24-2005, 03:11 PM
777's Avatar
oh dear lord...sorry to say but i think at first glance that was the funniest thing i have EVER seen. I thought you bought them and someone cnc'd them like that.. sorry to say you won't be getting much for them. The only way I see any use for them is if you got them cnc'd again for low compression, so you could remove all that damaged material.
Old 06-24-2005, 04:00 PM
zamboxl's Avatar
damn man ok i would say that yea those heads look a little f##uped damn damn man yea i would say that they pretty worthless.
Old 06-24-2005, 04:05 PM
no there not anyone who thinks that hasnt seen the **** i have with cylinder heads...i seen a set of AFR SBC heads come off the motor in 3 pieces and FIXED!!! and run for a few more years before SOLD!!!
i can have the combustion chamber tig welded back up and the hand smoothed out. they wont be CNCd but they will match the CC of the other chambers!!!
Old 06-24-2005, 04:27 PM
JZ'sTA's Avatar
They are fixable but for how much?
It is worth fixing them just to resell them?
Old 06-24-2005, 05:19 PM
PREDATOR-Z's Avatar
I think a new chamber can be welded in, kinda like they do for the LQ4/LQ9 59cc Patriots.
Old 06-24-2005, 07:49 PM
CharlieLed's Avatar
I was given a pair of heads off an 02 Z06 that sucked a valve, the combustion chamber looked alot like your head. It took about $160 worth of welding and machining (.007 milling) to get the head back to a point where I could finish the fine grinding and polishing. Those valves retail at about $75 a piece so you will have to consider that cost as well. I wouldn't invest the money in that head if I intended to sell it, there's plenty 243 heads out there for about $400 or less each
Old 06-25-2005, 06:25 AM
JohnnyStorm's Avatar
Do you know what were the circumstances were that caused this? Just how does the face of this Exhaust valve fall off? I know it's a hollow stemed, sodium filled unit, and I haven't heard of any failures with these valves. Could it have been high spring pressures?
Old 06-25-2005, 06:34 AM
LS1someday's Avatar
Was that on a Forced Induction motor that it was damaged? Look at the chamer to the left of the raped one in the picture. Is that silver flaking on the valve face from the damaged chamber or from detonation in that cylinder? The chamber to the right of the damaged one doesn't look so good either.
Old 06-25-2005, 08:44 AM
CharlieLed's Avatar
These valves do not fail under "normal" circumstances, but they do not tolerate contact with the piston. Disabling the rev limiter is the quickest way to make that happen.
Old 06-26-2005, 02:21 PM
true...but these are CNCd 243!!! and i dont know where you can get them for $400 a piece CNCd.
well it was a Crate 6.0 from Scoggin Dickey...the car that i was in had MULTIPLE problems with the ASSEMBLY of the motor from Scoggin Dickey. it was doomed from the day it was installed. it was only the 2nd 6.0 that they had put in a F-body. He was drivin it down the road one day and it just stared ****** CLATTERIN!!! BAD!!! hence i lil bit of head damage. adn GOD did it burn oil as you can see form the pic also!!! and the speckling on the left chamber isnt from detonation its just debris from the other chamber!!!
Quick Reply: Ls6 Heads???
