coolant crossover pipe
Old 06-24-2005, 02:48 PM
SSPerformance's Avatar
Default coolant crossover pipe
when u buy the ls6 style pipe that only use;s the front 2 what do u use to block off the back 2
Old 06-24-2005, 02:55 PM
Viper's Avatar
They ( SPDC ) sell little block of plugs. They are identical to the plugs in the front but don't have the bar between them. Also for bolts, I found the coil pack bolts fit perfectly in there as well.
Old 06-24-2005, 08:47 PM
u got a link to them
Old 06-24-2005, 10:39 PM
ROCNDAV's Avatar
A quick search showed this thread from 3 days ago:
https://ls1tech.com/forums/showthrea...79#post3100579
It has the part numbers that you need. GMPD (GM Parts Direct) has them but isn't a sponser.
SPDC is a sponsor: http://www.sdpc2000.com/cart.asp?act...tart&catid=873 should and they should be able to help you out as well.
D
Old 06-24-2005, 10:40 PM
racecar's Avatar
I put another LS6 type pipe in back, and ran a 1/4" hose to the front, connected it with a T. Now I have LS6 with cooling front and back. I think that is important because trapped air bubbles can lead to hot spots in the heads.
Old 06-25-2005, 10:16 AM
cALL me stupid but i cant find them on there site
Old 06-25-2005, 10:30 AM
ROCNDAV's Avatar
Yeah, they were designed for a reason. Whats funny is that it looks like I actually have the room for the LS1 style pipes under my fast 90 intake.
Old 06-25-2005, 11:24 AM
anyone got a direct link to the item i cant find it on spdc
Old 06-25-2005, 11:33 AM
FILAMENTWS6's Avatar
The GM part number is 12570678.
Old 06-25-2005, 12:10 PM
ROCNDAV's Avatar
Yeah, you enter the GM part number in the search box. Dont forget the gaskets. The plugs and front pipe come with orings. I'm not sure if these orings replace the oval gaskets that I see in the parts list and service manuals (nobody ever mentions the gaskets)
Old 06-25-2005, 12:18 PM
Y2K SS's Avatar
I just posted about this a couple days ago. This is the correct numbers for the items:
plugs GM#12563325
pipe GM#12568478
Old 06-25-2005, 03:10 PM
JohnnyStorm's Avatar
plugs GM#12563325
pipe GM#12568478
12568478 was replaced by 12578838 - Pipe Assembly
Old 06-25-2005, 04:14 PM
Y2K SS's Avatar
thats funny seeing as how I just picked up mine on thursday.
Old 03-18-2009, 09:49 AM
theapprentice's Avatar
Part number 12578838 was superseded by part number 12602544. searched at gm parts direct
Old 03-18-2009, 10:07 AM
LS1Tech Sponsor
Beau@SDPC's Avatar
I think i can end this pretty quick.
UPDATED PART #s
front coolant pipe - 12602544 - $36.05
rear plugs - 12602540 - $6.64 per
gaskets - 12551933 - $6.88 per you need 4 total.
bolts are anything you can find in a M6 x 1 x 30.
That is all.
those are up to date as of 3 mins ago
plus look at how old the posts are...
Old 03-18-2009, 02:29 PM
massconfusion's Avatar
why not just cut your ls1 coolant lines and silver the ends shut. If you don't know how any welding shop can do it for 10-20$. mine was twenty and works just fine. 8,000 miles on it.
Old 03-18-2009, 03:21 PM
ROCNDAV's Avatar
UPDATED PART #s
That is all.
So are those gaskets the little oval gaskets that go under the front pipe and rear plugs? When I ordered my pipe & plugs, there was no PN for the gasket and the pipe & plugs came with little rubber o-rings.
Old 03-18-2009, 03:44 PM
LS1Tech Sponsor
Beau@SDPC's Avatar
those little o rings wont work like you think they will. They are on the stock pipes as well that come on the cars. you will need the gaskets
Old 03-18-2009, 03:51 PM
ROCNDAV's Avatar
That's what I thought, I could not ever find the part number for those gaskets. Thanks. I take it you guys have these in stock regularly?
Old 03-18-2009, 03:52 PM
LS1Tech Sponsor
Beau@SDPC's Avatar
all day everyday...
Quick Reply: coolant crossover pipe
