Overtorqued crank bolt
Hey everyone. My friend and I put a cam into my GTO the other day and he happened to remark to me that we had to torque the bolt to 200 - 240 foot pounds.
This seemed a little excessive to me, but he says that the research he did showed the final torque specs to be at 240 foot pounds.
Now I did a search here and on a couple of other sights, and I get conflicting reports. One sight said to set the bolt at 240 Foot pounds and then retorque the replacement to 37 foot pounds, while another sight said that 240 foot pounds is the final torque spec.
Can you guy help me out here. Which torque spec is correct?
I have two extra bolts and plenty of time, so changing the crank bolt out isn't going to be a problem. But I would rather not have pull the radiator back if I don't have to.
Thanks
John
Thanks
John
Thanks
John
Thanks
John
You are supposed to stretch it into place. I believe the 37 lb feet + ~90* is right. (I remember thinking 110*)
I got mine to the max on my torque wrench (250 lb feet) and I don't think it had stretched quite far enough to meet spec, but I called it good.
Edit:
https://ls1tech.com/forums/showpost....9&postcount=49
Crankshaft balancer bolt (new), 140* final pass.
Edit:
After seating the pulley I just torque the new bolt as hard as I can using ~2ft bar and don't even look at degrees or torque. I've found out I can pull max 110 degrees after the initial torque.
I'll tell ya what you do. You pull the crank with the old bolt and tighten it as tight as you can with a 18" breaker bar. Then take it back off and do the same with the new bolt but leave it on. I see no point in even needing a toque wrench when no one can get it torqued to spec anyhow. They basically just tighten it until they cannot tighten anymore.
I put one crank bolt on too loose. It casued a mouse-like noise in the pulley system that drove me crazy (no pun).
So I got a huge lead pipe and 36 inch breaker bar and cranked that baby down extra tight - now the mouse is dead...
I suspect using the old bolt will work just fine but lets not re-hash the torque-to-yield bull **** again! Apparently, the engineers who designed this horse **** really brain-washed the public and casued GM to generate extra parts revenue.
These guys should get big stock option payments and cash bonuses for their good work...
Originally Posted by smask04C5
Aftermarket ARP bolt is torqued to 190 ft#'s.
Actually, I asked this question of a licensed engineer who studies metal in various design applications. He said the torque-to-yield idea is an interesting theory but is primarily designed to sell more factory bolts....
He concluded there is nothing special about TTY bolts; they are constructed just like the old-style bolts that people have been re-using for decades. The TTY system of tightening bolts is somewhat more accurate than just torqing in sequence to a specified reading. Apparently, that is the only advantage.
Yeh, according to him, you can use a TTY tightening method with used bolts and obtain a similar clamping result compared with new bolts.
I thought lots of shops now re-use crank bolts but I could be wrong...
So I used new bolts during the last build up but I still feel like a dope after I found out my Chevy dealer has re-used TTY bolts for years with no hicups....
Do not use an impact to install the crank bolt. That's what the majority will tell you, and I'm inclinded to believe them.
I'm sure GM makes a lot of money off of selling ~$5 crank bolts to us enthusiasts.
The correct way as explained on LS1HowTo.com is to get the pulley on. Then use the old bolt to tighten it on and go to 240 ft/lbs. with that bolt. Then remove that bolt and install the new one and tighten to 37 ft/lbs. Then tighten anothe 140 degrees. Then have a few because you will be sweating. I used a big *** torque wrench (250 ft/lbs), and a 30" breaker bar I bought in Pathmark for $9.99, yup Pathmark, and I weigh 205lbs stand 6'tall and had all the veins in my neck sticking out. But I did it and it's on there good. That was the first time. The second time I put it on I did the above and before I put the new bolt in I pinned the crank.
Use a pulley holder...
I just put mine on last weekend and muscles are still sore as heck. And no wonder... tighten to 240... loosen... tighten again to 120-140 degrees. Ouch!
The ARP instructions said 120 degrees which is about all I could do and I'm not a small guy either. The first 90 degrees I could do my hands, but the last 30 degrees I had to grab hold of the sway bar and push on the 1/2" breaker bar with my foot. It flexed so much I thought it would break. Time for a good breaker bar. Thanks to code4's pulley holder that made so much easier.
